Just 2 Simple Questions
also, what does scv or svc mean on the monsoon head unit with the 12 disc changer. the only thing i can think of if its a kind of attention button, or if it increases volume based on volume inside or around the cabin. its buggin the crap out of me. thanks
the acctual meaning is speed controled volume. it is in the manual
if you have an m6 car, alot of guys run the 85w-140 fluid in order to reduce the shock on things.
i've also read about not running synthetic in rear ends w/ auburn posi.
i ran valvoline non-synthetic 85w-140 in my 10 bolt and now w/ my 12 bolt. my moser 12 DOESNT whine with it, so it must be working pretty well.
you need a new gasket, and i like to use some RTV on both sides of the gasket as well. i'm an RTV freak of sorts lol
the SCV stands for speed volume controll or somthing similar, i like mine
there is a noise level sensor outside the cabin, and that **** around the volume button adjusts the sensitivity. i set mine one click down from max. Trending Topics
) , and some RTV are in order.i'm a fan of using gasket + RTV on stuff. i like the BLACK high-temp RTV, i've used it on all kinda stuff and it works awesome. plus it doesnt stick out like a sore thumb as some of the orange/blue crap does.
if your cover came with a gasket, hooray, but if it diddnt, you might want to go to the autoparts store and get one for a 7.5" 10bolt before installing (very cheap). i put the RTV on the rear end, then stuck the gasket to it, then put more on the cover, and then installed it. it can get very messy very quickly so be carefull
