Well i was replacing my knock sensors today and everything was going smooth until i tried to start the car!! It cranks but no ignition!! I checked all lines, sensors, fuses, and hoses and everything is in check. Does anyone have any idea what the problem could be?? Fuel injectors?? Spark plugs?? THANKS IN ADVANCE!!
-gabe
I just did the same thing last weekend. It's probably not the spark plugs or fuel injectors. If you had zero trouble starting before, it almost MUST be something you missed hooking things back up.
Before I fired mine I went through my Haynes book and looked at DISasembly procedure to mentally and visually double check that I had reassembled everything. I was extremely paranoid, but mine fired up.
