is it true
Old May 12, 2005 | 09:46 PM
volcanic2345's Avatar
Default is it true
if you time an 1/8 mile time by 1.57 it equals an 1/4 mile time
redaddiction's Avatar
No it is not true.
Old May 12, 2005 | 09:48 PM
BBADWS6's Avatar
There is a formula that has a few more decimal places than that, and it only gives you an estimate of what you will run. It is not precise.
Old May 12, 2005 | 11:14 PM
oh well i know a lot of people that use this so i was just wondering
Old May 13, 2005 | 12:46 AM
Elite_Hot_Rod's Avatar
1.57 is pretty accurate.
Old May 13, 2005 | 12:59 AM
Onyx Z's Avatar
I'm not too sure, but I think that's the right number used in calculations. The number varies for nitrous, supercharger, and turbo cars.
And as stated above, it gives you an ESTIMATE, it is not exactly what you will run.
Old May 13, 2005 | 01:07 AM
You will also have to take in aerodynamics my truck will do alot better in the 1/8 versus the 1/4 mile. Don't forget gear ratio's also.
Old May 13, 2005 | 02:20 AM
regorih383's Avatar
Im on FIRE
Old May 13, 2005 | 02:35 AM
5w20's Avatar
Originally Posted by regorih355
Im on FIRE
flaming hot cheetos got you again?
Old May 13, 2005 | 03:41 AM
goober35's Avatar
There is no formula that will work for every car. But you can come up with your own when you run the 1/4. This way u can figure out what u would have ran if you ran the 1/4 instead of the 1/8
Old May 13, 2005 | 04:19 AM
FIREHAWK #07's Avatar
Im on FIRE
WTF????
Old May 13, 2005 | 06:53 AM
Daley's Avatar
There's no way any formula could be considered anything more than an estimate. There are too many factors involved - someone mentioned aerodynamics already, and many more come into play. Sure, that number is a universally-accepted formula for a good guess, but it can't account for all the potential during the second 660 feet of track.
.02
Old May 13, 2005 | 09:12 AM
quicksilverado's Avatar
1.56 will be pretty darn accurate for a car, but it is not the same for a truck.
Old May 13, 2005 | 10:41 AM
BLACKND's Avatar
The calculation for my truck is closer to the 1.50 mark from 1/8th to 1/4.
Old May 13, 2005 | 11:03 AM
The multiplication factor is off some but not to bad. Most of your acceleration in the 1/4 is accomplished in the first 1/8th mile so it's off some. My car ran a 9.23 in the 1/4 on a 5.90 1/8th. So you can see that 5.90 X 1.57=9.262 while 9.23/1.57=5.878.
Old May 13, 2005 | 12:30 PM
BLACKND's Avatar
Actually I take that back, my calcs were like 1.54. Damn calculator was actin crazy or something.
Old May 14, 2005 | 10:13 AM
TWS's Avatar
TWS
I had heard and read 1.55 was the multiplier. FWIW
We all know that using a formula is just an estimate, be the multiplier 1.54, 1.57, etc. whatever. Guess I could go through my hundreds of timeslips and test it, but I really have other things to do with my time.
