Question about bleeding brakes...
Old May 20, 2005 | 01:19 PM
bbz's Avatar
bbz
Default Question about bleeding brakes...
I recently put in a SLP line lock kit and wondered if all 4 corners need to be bled and how?
thanks.
Old May 20, 2005 | 03:36 PM
mattr228's Avatar
i believe i had to bleed all four when i put my SLP line lock on, although i did my through vacuum bleeding or manual bleeding through a one way bleeder
Old May 21, 2005 | 08:17 AM
XtinctHawk02's Avatar
Bleeding your brakes are easy.
Do a search in the "Handling/Braking" forum, there are plenty of ways and idea's on how to bleed your brakes.
I recently did mine and it was easy.
Old May 22, 2005 | 02:01 AM
2KThunder's Avatar
Invest in a vacuum pump, like $25, makes brake bleeds a breeze, and a clean one person job.
Old May 22, 2005 | 03:00 AM
DONAIMIAN's Avatar
you can also invest in speed bleeders, they can be had for under 40 bux a set. Id bleed all 4 myself cause the fluid can get really nasty in a short amount of time. Start at the caliper furthest away from the master and work your way to the closest. (passenger rear, driver rear, passenger front, driver front). Pump the pedal till you see clean fluid and no more bubbles.
