Damn..my Z06 fixed itself..
Old May 23, 2005 | 12:50 PM
sc300's Avatar
Default Damn..my Z06 fixed itself..
i took it to HMP last friday and made a few passes. Since i was going to take it in anyway to have the tranny fixed, i didnt care if any would break. I had to bang the gears to get it in 2nd and 3rd...On the way home i raced a silver T/A..he beat me both times since i had so much problems getting into gears..So i just drove it home cruising up to 5th only since i though 6th was still jacked up..
i took the car out for a spin yesterday and was cruising around and noticed that the gear box was so much smoother and that the shift to 4th light was working again..So i got on the freeway and put it into 6th and its working again...I took the car to work today and everything is still working great..
Old May 23, 2005 | 01:33 PM
regorih383's Avatar
looks like your friend fixed it when you when to sleep.................
Old May 23, 2005 | 01:34 PM
chupr0kabra's Avatar
Sounds like maybe your slave is going out. After a little "mix-up" with the shop that installed my new clutch, I was having LOTS of problems getting into gear because the slave wasn't disengaging correctly. Turns out they didn't replace the slave.
Try this: Pump the clutch pedal quickly a few times to build pressure, then see if your shifts get smoother again.
-Mike
Old May 23, 2005 | 05:26 PM
INVISIBLEZ's Avatar
That was me playing with you Duy. The Z06 isn't bad for stock. I've just got a tad bit more power than the black knight.
Old May 23, 2005 | 05:40 PM
z06matt's Avatar
Hopefully it will stay fixed... But I'd still have it all checked out so you wont have any problems later down the road.
Old May 23, 2005 | 05:59 PM
ProjecT 9's Avatar
damn, i need grimlens like yours...my grimlens keep breaking ****...
Jon
Old May 23, 2005 | 06:59 PM
sc300's Avatar
damn..i got clowned by my girl for getting beat..she was teasing me, so i had to chase you down and raced you again and got beat again...Ofcousre i had to say that the tranny was jacked up...hehehehehe
she not used to getting beat from a roll like that..because we are usually in the supra.
Old May 23, 2005 | 07:06 PM
B-RAD2's Avatar
Jon
ya mine does too.
Old May 23, 2005 | 07:39 PM
INVISIBLEZ's Avatar
I just wanted to play, I'm glad you weren't in the Supra, maybe when the new upgrade comes @ the end of the summer I'll stand a better chance with ole blue.
Old May 23, 2005 | 08:33 PM
FIREHAWK #07's Avatar
new upgrade huh.....
Old May 23, 2005 | 08:50 PM
INVISIBLEZ's Avatar
That's it muffler bearings.
