headlight problem
Also is there anyway that i can get the headlight dowm till it gets repaired?? Thanks
It could be a number of things that might be wrong. When mine went out i thought my motor went out and i was going to have to buy another one but luckily Josh (the batman411) help me and fixed my headlight. He took the headlight cover off and slightly bent back one of the prongs in the housing connectors which wasent making contact therefore causing the motor not to spin. It works like new now. Lots of thanks to Josh. You may want to check your connectors, fuses and ip dimmer fuses. It could be something very simple to correct and spare you the cost of spending money on a new motor. Iam not an expert but if you need help let me know I saw how Batman411 did it. Let me know and i can call him if hes not busy then maybe he can help also
