Overheat problem
Old Jun 9, 2005 | 01:03 PM
Fun4All's Avatar
Default Overheat problem
My car overheats after a few hours of driving when I use my AC, even on the lowest level. After a while my temperature gauge will start climbing and I have to turn off my AC for it to go back down to the halfway mark. Does anyone else have this problem? I have a 2000 LS1.
Old Jun 9, 2005 | 02:07 PM
Saad06's Avatar
hmm... that makes no sence. when the AC is on, the AC fan is on, and it helps cool the engine a little more.. im stumpted.
Old Jun 9, 2005 | 02:17 PM
JackZ28's Avatar
Make sure your fan is coming on when the A/c is on.
Old Jun 9, 2005 | 03:30 PM
Saad06's Avatar
duh, i feal stupid.
Old Jun 9, 2005 | 06:08 PM
Seth's Avatar
I'm having the same problem. I'm sure its a fan problem.
Are these fans 2-speed? Because I think mine are both running.
I haven't had time to really investigate yet.
Old Jun 9, 2005 | 08:26 PM
ACW's Avatar
ACW
Yes, there is a low speed and a high speed. The fans are controlled by three relays to select the mode.
The PCM will turn low speed fan operation ON at 108°C (226°F) and OFF at 103°C (217°F), and high speed ON at 113°C (235°F) and OFF at 108°C (226°F).
