AC Lines
Old Jun 10, 2005 | 09:11 PM
jlrz28's Avatar
10 Second Fun Car
Default AC Lines
I had a the lower AC hose blow today. It made a big gash on the hose and now it needs to be replaced anyone ever have this happen to you?? I really dont know how it happen it just blew and fluid went shooting out from under the hood! Anyone ever had this happen? Im not sure how much oil to put back in the compressor since I really dont know how much came out. Any help greatly appreciated!
Old Jun 10, 2005 | 09:52 PM
JackZ28's Avatar
I had an a/c pipe rub up against the sway bar and that made a hole, causing it to leak out in Germany. Now I just don't have any a/c at all.
Old Jun 10, 2005 | 10:15 PM
4thgen's Avatar
JackZ28 i to have Been there Done that, it sucks, damn sway bar
yes it needs oil, dont know how much.
Old Jun 11, 2005 | 02:44 AM
ACW's Avatar
ACW
The simplest way to be sure you have the right amount would be to drain whatever is left of the old oil, and re-fill with 60 ml (2 oz) of new poly-alkylene glycol (PAG) oil.
If you use the compressor crankcase oil drain bolt, when it's reinstalled it should be tightened to 20 N·m (15 lb ft).
