o2 sensor help
Old Jun 13, 2005 | 08:32 PM
ssfirefighter's Avatar
Default o2 sensor help
I had a 224 cam with duals (no cats) and long tubes. I had 50,000 miles on the o2 sensors on the car with no problem. I put back on the y-pipe with cats, and the cat back to get my inspection sticker, and the SES light came on. It was originally reading bank 2 sensor slow response, and a maf code. Then, I had my x4 cam installed, went back to the duals for the tune. After the x4, my codes were cleared, and the SES light reappeared, to read bank 1 & 2 along with the maf code. I have since reinstalled the catted y, and replaced to o2 sensors from a friend's car that I know worked, and my SES light is still on. Any suggestions on what else could be wrong?
Old Jun 13, 2005 | 10:34 PM
H/C LS6Z's Avatar
What codes are u throwing? I'm going through a **** load of o2 problems right now with my LT's
If you're trowing the PO135 or PO155 codes then you've got the same problem I've got right now and trust me I've been dealing with this crap ever since I got my LT's on 3 months ago and I still can't figure it out!
LMK what codes you're throwing and then it should clear up the matter
Old Jun 14, 2005 | 07:00 AM
Those sound right. But I am also throwing a 1133 I think. I have never had a problem with my long tubes. I have had them on there for 25-30k. There was a few times that I started up on a cold morning, and the light came on, but went off on itself.
Old Jun 14, 2005 | 04:32 PM
JackZ28's Avatar
How were the codes "cleared"?
Old Jun 14, 2005 | 06:32 PM
Tech2
Old Jun 14, 2005 | 08:04 PM
slowpoke96z28's Avatar
where is hurst? is it close to houston? i got a diablo predator, maybe we can do some data logging and see exactly when the codes come.
Old Jun 15, 2005 | 02:15 AM
Renfro's Avatar
well if is't not tuned look ip how to pull the two fuse to clear the codes drive it there and you will be fine. Did it with mine no prob, I too have lt's. And that should do.
