car smokes
Old Aug 13, 2005 | 02:54 PM
sleeperZ2000's Avatar
Default car smokes
iv been told that it could be the pcv vale is this true or could it be something else. the smoke is a bluish white color. car has 70k plus miles on it.
Old Aug 13, 2005 | 03:18 PM
White 02 WS6's Avatar
When does the car smoke?? Idle, WOT, crusing, starting, letting off the gas?
Old Aug 13, 2005 | 04:41 PM
sometimes at idle like if it sits for a long while and it does it every time i get on it
Old Aug 24, 2005 | 06:28 PM
hepcatws6's Avatar
I am in about the same situation with my WS6. Idles rough, smokes (Even worse when I am giving it gas, and white smoke from the pipes.) Also the SES light blinks every once in awhile indicating a multiple cylinder missfire it would seem.
Old Aug 24, 2005 | 06:48 PM
JackZ28's Avatar
Where does the smoke come from?
Old Aug 24, 2005 | 08:34 PM
White smoke is wator vapor...Your blinking SES light from multiple misfires makes me think that you have either a head gasket leaking or a crack in a water jacket...This would also be causing the rough idle...
Old Aug 25, 2005 | 12:45 AM
raven4960's Avatar
watch the smoke...if it fades about 20" from the pipes its water...if it is thicker, like fog and doesn't dissipate then it could be coolant or oil. Hopefully just a blown head gasket...could be a bigger problem though
