Weird Clutch ?
Old Aug 24, 2005 | 09:00 AM
John98LS1's Avatar
Default Weird Clutch ?
ok just installed a new spec3 under warranty (this is my 3rd).. everything is fine, my probleam is if i wanted to i cant hit the gears hard. I bleed the air in the line already. also my engament point is not strong, but it has changed its now like right off the floor which doesnt make sense since i have a adj master that has been setup fine for 2 spec stage 3 clutchs and theres about 1inch of play before u start to feel the clucth when u press the pedal.
please help me out. thanks guys
Old Aug 24, 2005 | 11:59 AM
SpeedDemon's Avatar
sounds like you either need to adjust the master or bleed the clutch better....
You could also call me....
Old Aug 26, 2005 | 08:36 AM
John98LS1's Avatar
i have tried calling u! what the hell is wrong with cell's this week, my nextel is going nuts since sprit took over
