PLEASE pordon double post - quick help
Old Sep 12, 2005 | 07:43 PM
SS SLP2's Avatar
Default PLEASE pordon double post - quick help
I received moser # MSR A102806 ( stamped on box from moser) which state for 4 channel ABS, MOSER # MSR A102805 which states fo 3 channel, so I beleave the box is correct, BUT I think the axel are wrong, these axel DO NOT have the RING at the end for traction control, is it possible ( and how much problem ) to press the rings from my axel and reinstall to the new moser axel, my supplier is going to set up a 3 way call with moser in the morning , but I need to know if THE 4 channel axel SHOULD have the ring allready install , 60.00 differance in price between ondering the 3 channel and ordering the 4 channel ( do nor care about price)any differance between 3 and 4 channel axel , I orded the --806 4 channel thinging I would NOT NEED to remove the ring from my axel
PLEASE some one explain
>>>AND yes I poster a inquire trying to buy from our sponsers
Thanks for ALL REPLYS , Johnny
Old Sep 12, 2005 | 11:38 PM
SpeedDemon's Avatar
Axles are the same. Moser has their own reluctor gears though. I am not sure you can use the factory ones. I do have some laying around if you need them and want them quick.
Good luck,
Old Sep 13, 2005 | 05:09 PM
SS SLP2's Avatar
Chris check your PM , need ph # thanks ,Johnny
