Speed up for Mozilla(free mod)
Found this mod while sitting bored in Columbus during evacutaion time.
i've been through about config a million times
I'll go find my speed tips for firefox too... there are a ton.
Try this! http://kb.mozillazine.org/Logitech_mouse
i think its the mx700 duo or something
but the middle button doesnt allow me to "click" to open in a new tab, or click in the page to scroll/slide up and down...
1.Type "about:config" into the address bar and hit enter. Scroll down and look for the following entries:
network.http.pipelining network.http.proxy.pipelining network.http.pipelining.maxrequests
Normally the browser will make one request to a web page at a time. When you enable pipelining it will make several at once, which really speeds up page loading.
2. Alter the entries as follows:
Set "network.http.pipelining" to "true"
Set "network.http.proxy.pipelining" to "true"
Set "network.http.pipelining.maxrequests" to some number like 30. This means it will make 30 requests at once.
Set "browser.turbo.enabled" - to "true"
Set "network.dns.disableIPv6 - to "true"
3. Lastly right-click anywhere and select New-> Integer. Name it "nglayout.initialpaint.delay" and set its value to "0". This value is the amount of time the browser waits before it acts on information it receives.
or Broadband users only. The following should help increase surfing speed of Mozilla Firefox (which is tons better than Internet Explorer). If you don't have FireFox, I recommend you getting it at www.getfirefox.com
:edit: Repost but I have 2 things extra.
If you have Firefox, do this:
1.Type "about:config" into the address bar and hit return. Scroll down and look for the following entries:
and browser.turbo.enabled
Set "browser.turbo.enabled" to "true"
3. Right-click anywhere and select New-> Integer. Name it "nglayout.initialpaint.delay" and set its value to "0". This value is the amount of time the browser waits before it acts on information it receives.
4. FOR XP USERS SEEKING FASTER FIREFOX LOADTIMES: Within the Firefox "shortcut" icon properties add /Prefetch:1 (outside the quotation marks) of the 'target. For example: my target is "D:\Program Files\Mozilla Firefox\firefox.exe" /Prefetch:1
If you're using a broadband connection you'll load pages MUCH faster now!
From the source:
* Description: maximum number of consecutive requests in one pipeline.
* Type: integer
* Limit: 8
* Default: 4
* Additional Info: nsHTTP.h. Optimal value depends on connection bandwidth/latency.
* Recommendation: 8. While it doesn't hurt to set it to 100 like in other tweak examples, it will have no effect whatsoever because of the mentioned limit.
So setting it to 30 won't do anything. Set it to 8.
Also, not all servers support this feature. So only some sites will speed up.
http://www.subterrain.net/drupal/make-firefox-faster
google.com has some if you can weed out the crap
i had some pages from ls2 but they are all gone. like looooooong pages of stuff to do.
