Bryan/CS Help needed
Old Oct 17, 2005 | 01:25 AM
resurrectedz28's Avatar
Default Bryan/CS Help needed
Alright, basically I need some suggestions on where to take my car to get it worked on. I already know dealerships, so I wanted to know of any shops that people might have experience with.
This will be the first and hopefully last time it has to go, its got an electrical problem somewhere causing a no start condition. Already pulled starter and tested it, checked fuses and battery, and then replaced the ignition switch (a bitch of a job) to no avail, so this is beyond my know how. Ive got a volt meter, but Im in the dark as how to use it properly.
Any help/suggestions would be greatly appreciated- its a 93 z28.
Old Oct 17, 2005 | 02:11 AM
RoAdRaGe912's Avatar
bah, just ask me more questions and get will's magic book. we can fix dat ****.
Old Oct 17, 2005 | 10:08 AM
01WS6/tamu's Avatar
I am assuming the definition of no start is that it will not turn over correct? Is the security light flashing during the attempt? If yes lock cylinder. I have had the factory starter interupt relay for the Vats go bad on a few cars in the shop. Do you have any type of nonfactory alarm. Is the problem intermittent or is it dead in the water. I work at an audio shop here in town so if you need a hand drop me a line. If I dont have the tool snap on doesn.t make it. Or if you wnat to go to a shop Sevciks Texaco on longmire is hands down best and honest outside of tom light. Later
Old Oct 17, 2005 | 05:32 PM
^^^^Full story: Since I got this car every now and then i would go to start it and I would here the solenoid click, but it would not crank (no pattern to it, random all the time). I learned to just let it sit for awhile and it would always eventually crank and start. So this last time it happened I let it sit, tried it a few times, and on the last try I heard the solenoid click and then a fizz like when you open a coke can, and no cranking/start. Now the solenoid doesn't click, its dead in the water.
Does have an aftermarket alarm, but i honestly don't think that is the problem, never was in the past, and the security light does not come on.
Thanks for the tips though, and i might end up having to call you or something if i cant figure it out.
Old Oct 17, 2005 | 05:38 PM
01WS6/tamu's Avatar
Where did the fizz sound come from underhood or dash. It could be a ground or just a bad battery. We could tell real quick up close it's just hard to diagnose without putting your hands on it.
Old Oct 17, 2005 | 07:30 PM
Ill rule the battery out for sure tomorrow, ****, if it starts ill be pissed and there will be a new dent in the quarter panel, but im pretty sure it wont.
Will, if you read this, can i take a look at your books and get more confused?
Old Oct 17, 2005 | 11:28 PM
DesertFox's Avatar
Where are you at man, we can all come over and take a look at it. It sounds like maybe your solenoid took a dump, if the fizzing came from under the hood. Let us know.
Josh
Old Oct 18, 2005 | 12:33 AM
he put a new solenoid on it a couple days ago and i made him get the starter checked out. definitley not a VATS problem. he picked up a multi-meter but hasn't checked out the wire from the battery to the starter (at least to rule it out, low possibility but need to do it).
i'm almost 100% it's somewhere in the remote wire. it's a good amount of wire to follow and test out and i dont' have the gm service manual but will does.
i'm free tomorrow after 1 pm all day and if u wanna do some testing or need will's number just gimme a shout and i'll run u through it.
Old Oct 18, 2005 | 12:59 AM
will69camaro's Avatar
Sex On Wheels
I'm busy alot of tomorrow and the next day but thurs and fri are pretty light for me. I can meet you somewhere and drop off the manuals if you need them. They're sitting on a shelf beside me. I hope you get ol' purple fixed, so i can get Kat's stang it's first kill
William
Old Oct 18, 2005 | 09:27 AM
Im going to give in and get a flatbed to tow me back to my apartments either today or tomorrow so it will be at The Ridge. Will, ill give you a call friday after 5 if your not doing anything.
Old Oct 18, 2005 | 11:46 AM
01WS6/tamu's Avatar
If it is not getting signal to the starter during crank the factory starter interupt relay for the vats could be bad. It will not make the security light flash either bc the vats has give a systems go command. Is it an auto or a stick. Check your park neutral switch. The wire runs from the ign switch through the p/n switch through the factory vats starter diasble then changes to purple and runs out to the starter. A bad cable could be the root of all evil too. It can show power but not be able to handle load.
Old Oct 18, 2005 | 12:45 PM
Its an auto, I did try to start it in neutral but still got nothing. Im not knowlegeable enough with this voltmeter to know how to use it/interpret the results to run the checks. Where is the starter interupt relay for the vats located?
Old Oct 18, 2005 | 06:42 PM
sleepersilverado's Avatar
do something as simple as tap om the starter sylinoid while someone trys to crank it. real simple and eventhough you replaced the sylonoid does not mean it is good. i could also help you but it has to be after 6 when i get off work. just holla i think you know brandon and he can get ahold of me.
Old Oct 18, 2005 | 08:03 PM
sleek silverado's Avatar
Yep, you are correct!
Old Oct 18, 2005 | 08:14 PM
01WS6/tamu's Avatar
Damm if I can remember I'll have to check alldata at the shop tomorrow. Pop the top on the center console and see if you are getting 12v out on the purple wire.
Old Oct 18, 2005 | 08:21 PM
alldata is the **** most the time
Old Oct 20, 2005 | 12:55 PM
Thanks again for the help the other night Brandon and Ryan. Ill get back on it later today to see if I can find that vats relay thing. If worse comes to worst ill wire up a push start like you all said.
