anyone know what this is??
Old Nov 3, 2005 | 09:03 AM
Pavlock Performance's Avatar
Default anyone know what this is??
this is why i cant run the car right now but when i floor it , everynow and then it will stay reved really high even though my foots of the gas.. the only way to get it back down is to pop the gas peddle a little bit reving it up and down and eventially it will return to idle.. i dont think anything is stickin in the TB but maybe its a sensor like W.O.T sensor??? anyone else experience this or know how to correct this??
Old Nov 3, 2005 | 09:14 AM
Dustin's Avatar
your car is junk, drive it off a bridge
Old Nov 3, 2005 | 09:21 AM
imnotplutonium's Avatar
harsh
Old Nov 3, 2005 | 09:39 AM
Morbid's Avatar
Have you tried turning off the car, disconnecting the throttle cable and opening/closing the TB by hand? That'd cancel out a few things right there.
Old Nov 3, 2005 | 09:45 AM
xaon's Avatar
check to make sure there is no slop in the throttle cable if you have a TCS car. Mine did something similar until I adjusted the slack out of it.
Old Nov 3, 2005 | 10:23 AM
ha!! it'll still beat you "monkey lover".... haha...
thats okay i wont tell anyone Dustin
it's not a tcs car, and it only does it under a load...
Old Nov 3, 2005 | 10:27 AM
Dustin's Avatar
Whenever youre ready to run *** clown, dont back down when i call you out.
Old Nov 3, 2005 | 10:28 AM
MAXIMO's Avatar
So when is the last time you did a tune up? Plus and Wires
Old Nov 3, 2005 | 10:32 AM
sammyb's Avatar
take your throttle body off and clean it. my 00 ss did the same thing. It was sticking, i cleaned it and it didn't do it for a while, then i replaced the tps sensor, throttle positioning sensor and it never did it again.
Old Nov 3, 2005 | 10:36 AM
Inspector12's Avatar
TT-TECH Veteran
Look there are only a few things that control this. The IAC, may be getting stuck and letting to much air by and that will cause it for sure. If your sure the throttle cable and all is clear of any physical obstructions then that is the first place I would start. Take it off and inspect it anyone with a tech 2 can maually move it in and out for further diagnosis etc... Fairly easy fix though. And when you both want to get drug let me know I am sure I can accomodate you LOL! Just jk wanted to get in on some of the little smack talking. Hope this helps.
Jeff
Old Nov 3, 2005 | 11:31 AM
Pshhh!! whatever dustin... ill smack that *** WITH all your spray and me n/a...
pick the car you wanna run, nova or formy and get drug just like my name tells you haha....
okay, back to this: ill take it off and look at the sensors... can you clean them with anything withyou harming them???
Old Nov 3, 2005 | 11:59 AM
TT-TECH Veteran
I am not sure how delicate they are or are not I would assume you can use some kind of brake parts cleaner on it seems like I've done that before. No promises though.
Old Nov 3, 2005 | 12:16 PM
V6 Bird's Avatar
Ive seen K7N gaskets get lodged in the blade before and cause this....
Mike
Old Nov 3, 2005 | 12:42 PM
SUX2BU's Avatar
stock throtle body?
Old Nov 3, 2005 | 03:02 PM
i looked at the TB and it looked fine inside... didnt take it off but just opened the blades.. it doesnt do it THAT much but it's about a 50-50 chance that it will happen if i get on it... Yes stock TB but its ported..
Old Nov 5, 2005 | 12:34 AM
joshtownsend's Avatar
I have had this happen to me when i got rid of my egr. It was getting too much fuel in the intake and ran like crap.. But i think you would know it if you were missing it.
Old Nov 5, 2005 | 01:36 AM
Bad Blu Formula's Avatar
SaW you run the car at the track tonight. Looked like it was doin ok? Just cleaning it with that brake parts cleaner should do the trick.
Old Nov 5, 2005 | 09:10 AM
ha! guess you came late when i finally made 2 okay passes lol... the other ones were all crap or the throttle getting stuck wide open and having to just let off of it...
Old Nov 5, 2005 | 10:19 AM
alexf20c's Avatar
Jeff
The IAC only works at IDLE. Even at 100%, it can't raise the rpm to the levels the dude is talking about. The throttle plate is sticking.
Old Nov 6, 2005 | 12:33 AM
the reason that i dont think the throttle plate is sticking is because when it's reving high on it's own, i can shut the car off while im driving and restart it and it's back to normal idle. So my thinking is that if the throttle blade WAS stuck open, then when i restarted the car it should STILL be stuck...
So i have no damn clue lol.. just think it's one of the sensors??
