FS: '98 Z28 6spd
Old Nov 3, 2005 | 06:40 PM
TXB4Z's Avatar
Default FS: '98 Z28 6spd
$7000
posting this for a friend. please contact him
"Time to sell my 1998 Z28 M6 with 109xxx miles. This 1998 has every option except TCS and maybe any other rear end gear option that there was. The car has power seats, window, door locks, keyless entry, leather, t-tops, monsoon sound sound system. Most of the mileage is highway mileage from previous owner who was a female that drive across Texas. Since I have had the car it has only seen mobil 1 synthetic with an AcDelco oil filter. Transmission fluid was swapped out at 95K when I bought the car with Amzoil synthetic ATF and Differential with Amzoil synthetic gear oil(including GM Diff. additive). I replaced the clutch at 102xxx with factory ZO6 clutch and flywheel and also replaced slave cylinder and clutch master cylinder and transmission mount was replaced at 107xxx miles. Vehicle has factory C5 speedline wheels with Goodyear EMTs same size as the Vette. Front tires are 7/32 and rears are 4/32. New brake pads and brake rotors on the front and the rear brake pads still have about 40% remaining. Paint is in good condition with minor wear @ 109K as well as interrior is in good condition with minor wear on drivers seat. Only Mods to the car are SLP loudmouth 2 exhaust system, k&n filter and short stick shifter. Car is Blue w/light charcoal interrior. Everthing on the vehicle works great including the famous window motors. AC also blows cold."
contact him at
ats_hunter@yahoo.com or 512-515-0091
his name is andrew
Old Nov 4, 2005 | 10:26 AM
LS1powerhouse02's Avatar
Where is this car located at?
Old Nov 4, 2005 | 05:08 PM
TXB4Z's Avatar
leander, tx. just a little north of austin
