Help,Ta owners!
Old Dec 16, 2005 | 07:55 AM
628soon's Avatar
CRAGER,It's bone stock, sorry for the camaro misspellling. At start up hers was almost peg'd out. I apologise for all the literary mistakes,the incident happend moments before I posted.
Old Dec 16, 2005 | 08:43 PM
628soon's Avatar
Alright I'm back just checking in to see if this got me yelled at yet.
Old Dec 16, 2005 | 09:41 PM
CRAGER's Avatar
Administrator
You're not being yelled out man, no worries.
Oil pressure high, fine, low oil pressure bad. I don't know how you got 80psi, but just keep an eye on it.
Have you checked it out since all of this happened, have you started it or anything?
Peace,
Craig.
Old Dec 18, 2005 | 03:11 AM
628soon's Avatar
CRAGER,yeah we went out xmas shopping in it this weekend,It's doing some other weird stuff though ,#1 When you start it now all the needles on the dash are maxing out. #2 trip meter resets itself every time you start the car. Any of this familiar to you my friend?
Old Dec 18, 2005 | 11:39 AM
CRAGER's Avatar
Administrator
https://ls1tech.com/forums/showthrea...ght=gauges+peg
Search is your friend!
Good luck trying to narrow it down. I hope you figure it out, and let us know what your cars problem was so you can help others.
Peace,
Craig.
Old Dec 18, 2005 | 03:06 PM
628soon's Avatar
Thanks brother ,the search function has been screwy as of late, so its been no real help.
Old Dec 21, 2005 | 11:13 PM
628soon's Avatar
Checking in on this again.
Bump Bump
Old Dec 22, 2005 | 08:03 AM
SuperGook's Avatar
on start up mine is usually around 60-65, after warm up 45-50,when i'am in it hard 65 plus. It's a 2000
Old Dec 22, 2005 | 11:23 AM
LS198Z28's Avatar
if this helps my camaro has always had high oil pressure about 60 psi when i start it up cold ( when it is as cold as it is now outside) when it is warm it is just under 40 psi. hope this helps
btw 128000 on car 20,000 miles since motor rebuild
Old Dec 22, 2005 | 01:20 PM
DONAIMIAN's Avatar
the gauges doing that sounds like a low battery
Old Dec 22, 2005 | 02:06 PM
MAXIMO's Avatar
I ran 5w 30 then on start up it was above 80 then warm it was 40 on the gas up to 80
recently had the motor rebuilt
craped out on me again
10w 30 start up the same warm looked like right above the redline on no pressure. on the gas was 40. I trew another lifter. So its back at the shop.
Old Dec 23, 2005 | 12:08 AM
  #32
628soon's Avatar
Thanks fellas I'll keep checking back.
