i need a nitrous 120 shot pill..
Old Dec 26, 2005 | 06:24 PM
sc300's Avatar
Default i need a nitrous 120 shot pill..
and some corresponding fuel jets...i want to spray 120 but most kits (import wise) come with only 90-100shot..
thanks
duy
Old Dec 26, 2005 | 07:07 PM
crAzy95Z28's Avatar
go to MTI
Old Dec 26, 2005 | 11:40 PM
Inspector12's Avatar
TT-TECH Veteran
Hey Duy it might help if you new what the jet sizes were and then some one could chime in weather or not they had them etc..
Old Dec 27, 2005 | 01:30 AM
1 Bad Z's Avatar
Duy, if you are using this with LS1 fuel pressure, then you need a .057 nitrous and a .033 fuel jet. At 900 PSI, this will be roughly a 120-125 shot. I may have them. I'll check tomorrow.
Old Dec 27, 2005 | 09:29 AM
sc300's Avatar
i dont know the actual number of the jets..im spraying 120 on my supra, but it was drilled out by HPE..i want to spray the same for the nissan..i know that under boost the fuel pressure increases to around 5bar. (60psi)
Old Dec 27, 2005 | 11:48 AM
Ben R's Avatar
Isn't 5bar closer to 72/73 PSI?
Old Dec 27, 2005 | 11:59 AM
sc300's Avatar
yeah..70psi..thanks
