Security Light Stays On
Old Jan 2, 2006 | 11:01 PM
ls12000's Avatar
Default Security Light Stays On
The other night i started my T/A and the security light in my dash came on and now it wont turn off. Has anyone else had this problem and how do i get it to turn off. Thanks
Old Jan 2, 2006 | 11:54 PM
LT14Formula's Avatar
yes, and no I don't know how to fix it. lol
But mine occasionally turns on but it usually turns itself off. Its annoying because its a very bright light.
- LT14Formula
Old Jan 3, 2006 | 12:11 AM
Coy's Avatar
Coy
reset the computer. Unless its electrical problems, that should take care of it.
Old Jan 3, 2006 | 01:58 AM
highgear's Avatar
The only time my security light stayed on was when my battery was getting ready to crap out.
Old Jan 3, 2006 | 08:27 AM
chupr0kabra's Avatar
I had that problem and also had problems getting the car to start. I ended up having to get the whole tumbler replaced. Not cheap.
-Mike
Old Jan 3, 2006 | 08:31 AM
Morbid's Avatar
... and what chupr0kabra means by "tumbler" is the lock cylinder in the steering column. Mine did the same ****.
Old Jan 3, 2006 | 09:03 AM
gavspurplez's Avatar
i work at a dealer and one of the techs has a firebird with the security light on.
the vehicle starts and runs but the light stays on. the key does not have the chip in/on it.
any ideas ??
Old Jan 3, 2006 | 10:18 AM
Morbid's Avatar
any ideas ??
One of the tech's has a problem and can't diagnose it? Wow. What do they pay him for again?
Check the BCM (Body Control Module.)
Old Jan 3, 2006 | 02:54 PM
ls12000's Avatar
How do you reset the computer. Will resetting the comp have any affect on my shift points because i had them reset when i changed out my gears and had my car tuned.
whatever the problem is i hope it's not that serious and costly.
Old Jan 3, 2006 | 03:12 PM
Morbid's Avatar
Search works wonders.
Anyway, turn key on but don't start car. Pull the PCM BAT and PCM IGN fuses in the engine compartment fuse box. Wait 10 minutes. Turn ignition off. Replace fuses.
Resetting the PCM will not affect your tune. Tunes are stored in flash memory, the only way to lose that is to reflash the PCM.
Old Jan 3, 2006 | 10:11 PM
5w20's Avatar
Old Jan 3, 2006 | 11:09 PM
R_DEL's Avatar
I had the same problem mine just went off by itself after a few days.
