help with SLP Header Installation?
Old Jan 31, 2006 | 02:43 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
150$?!!?!?!?! how is he your buddy?!
Old Jan 31, 2006 | 02:47 PM
SHINER's Avatar
i dunno. i just wish some one could atleast just be there to walk me through.
Old Jan 31, 2006 | 02:51 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
All you need is a couple 2x4 blocks and a jack with jackstands. It gets pretty scary for as high as you need to get it in the air. And as a side note the SLP's are going to need a good amount of space to get through.
Old Jan 31, 2006 | 02:55 PM
SHINER's Avatar
how do i do it, do i remove the K member and then put the 2x4s on the oil pan then jack the engine up or what?
Old Jan 31, 2006 | 03:13 PM
RYNO_Z's Avatar
I went to A&M Galveston...graduated May 04. Actually I put my headers on a couple months ago in my buddies garage in galveston. Took a while, but we took a few breaks and there was beer involved. What I did was jack up the front as high as I could, then put jackstands underneath with 2x4's. I then jacked up the back and put the rear tires on ramps. It may seem a little over-kill but you need all the clearance you can get. The more clearance you have the easier the install is. Just take your time.
Old Jan 31, 2006 | 03:17 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
The time consuming portion is just getting it up in the air. I jacked it up on the k member with the 2x4 blocks. And then moved the jackstands next to the front of the Subframes.
Old Jan 31, 2006 | 03:20 PM
SHINER's Avatar
do i have to unbolt the K member and LCAs and ****, i dont want a realignment.....please enlighten me!
Old Jan 31, 2006 | 03:38 PM
SHINER's Avatar
ttt!!
Old Jan 31, 2006 | 03:46 PM
RYNO_Z's Avatar
shouldn't have to unbolt any of that...just get it up as high as you can. you might have to unbolt the motor mounts from the k member and lift the engine up but there shouldn't be any reason to remove the a arms.
Old Jan 31, 2006 | 03:49 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You dont have to. just jack it up from the k member with the 2x4's...you will be fine man. It is scary, but if you have enough support it wont fall. Just be careful and take your time.
Old Jan 31, 2006 | 03:52 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I have done it this way for a while on Hookers, FLP's, and Pacesetters.
Old Jan 31, 2006 | 03:55 PM
  #32
SHINER's Avatar
alright well ill post in about a week or two and let you know how it went. thanks ill repost on here if i have more ?'s.
Old Jan 31, 2006 | 03:57 PM
  #33
RYNO_Z's Avatar
good luck man...if you have any problems post em up here. that's what this place is for.
Old Jan 31, 2006 | 03:58 PM
  #34
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I will be on all night long. Just hit me with a PM or post up.
Old Jan 31, 2006 | 04:03 PM
  #35
cyphur's Avatar
dude....sell the SLPs...save up....buy Kooks or QTP headers - and then go about installing it.
i wouldn't install SLP headers if someone GAVE them to me. bye bye ground clearance!
Old Jan 31, 2006 | 04:08 PM
  #36
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yeah, but some people do it for the nastalgia factor, so I wasnt going to say anything to him derogatory...all though that is a good suggestion.
Old Jan 31, 2006 | 04:10 PM
  #37
SHINER's Avatar
guys i bought these used from a member on here, im getting SLP LTs, ORY, and extensions, for 320 bucks!!!! who can pass up on that deal honestly?????
Old Jan 31, 2006 | 05:32 PM
  #38
leeluther252's Avatar
No you dont have to undo the K-member or A-arms.. For Slp Longtubes both will go from the bottom. The drivers side is not too bad. Remove the Stearing arm and you will be fine. If you need a little more space remove the oil filter. The passenger side is the hard side for these headers. Take the tranny brace off and let the tanny hang down some. Have someone pry the tranny to the drivers side and with some work it will go in. I have to go to school.. if you need some tips.. pm me.. ive dont these headers 5 times
Old Jan 31, 2006 | 09:45 PM
  #39
SHINER's Avatar
ttt for advise!!!
By Brett Foote | 2026-06-04 05:00:17
