Damn it
Old Apr 24, 2006 | 08:28 PM
BizZzatch350's Avatar
Moderator
Default Damn it
Driving home from work, my Trans Am sounded like it had an exhaust leak, all of a sudden it got loud as **** and sounded like a harley, dont know what the happened
Old Apr 24, 2006 | 08:32 PM
Sprayed1998's Avatar
prop came undone somewhere, im sure youll find it easy
Old Apr 24, 2006 | 08:33 PM
SSilverSSurfer's Avatar
i think you were sitting on the cutout switch
Old Apr 24, 2006 | 08:38 PM
MrBill97396's Avatar
Header bolt back out ? or do you have manifolds stil ? If the manifolds are still on there maybe one cracked, saw alot of that when I worked at a muffler shop.
Old Apr 24, 2006 | 08:53 PM
Moderator
Still has manifolds, driving to work it sounded like it had a slight exhaust leak, then all of a sudden it sounded like a helicopter. This motor has 69K babied miles, it isnt whored, never saw gas, I'm hoping its just a really nasty exhaust leak. I'm in the middle finals too now, like a dumb **** I dropped the Blazer off for warranty work this morning, only if I knew, so now I just went from two cars to zero.
Old Apr 24, 2006 | 09:02 PM
Try and pinpoint where the noise is coming from Neil. Pop the hood, jack the car up, or just run it by a shop when you get a chance. If it is a manifold then you have no excuse not to get LT's.
Old Apr 24, 2006 | 09:03 PM
408WS6's Avatar
To me it sounds like a manifold gasket. When you mention helicopter, it sounds like its just leaking from one cylinder.
Header gaskets blow all the time. But I've never heard of anyone blowing a manifold gasket I guess theres a first for everything...
Old Apr 24, 2006 | 09:07 PM
Manifolds cracking is what I have seen cause the noise that he is describing, or it is in the exhaust pipe close to one of the manifolds.
Old Apr 24, 2006 | 09:16 PM
LS1 KLR's Avatar
Mustang Moderator
Urgh! manifold gasket would suck to fix!
Neil - get a piece of vacuum hose and use it to help you "hear" the leak...check around the manifold, the gasket and such.....if it is as loud as you say you should have no problem pin pointing the leak!
GOOD LUCK!
Old Apr 24, 2006 | 09:22 PM
Moderator
Thanks guys, I'll check when I get light, Its comming from the passenger side head area, it has to be some thing with that exhaust just as loud as it got. I have heard cars with broken motors before, your can hear the noise but its not this loud, drives fine though, it got me home with out wanting to die, oil presure seemed great. Mr.Bill, prety much the rest of my long tube stuff came from Thunder this morning. If it has to do with the stock exhaust, no way I'll fix it, planning on long tubes here in a few weeks any way. Maybe this was god finally getting mad and telling me to hurry my brown *** up and put headers on the car.
Old Apr 24, 2006 | 09:29 PM
408WS6's Avatar
Also Neil, what did you have for lunch today? Everytime I eat mexican food it sounds like an exhaust leak
Old Apr 24, 2006 | 09:30 PM
Moderator
If your farts sounded like this, then your a god among men.
Old Apr 24, 2006 | 09:40 PM
Tiago's Avatar
I think its asking for expedited LT's
Old Apr 24, 2006 | 09:44 PM
408WS6's Avatar
Well they may not sound like that, but I'll bet they smell just as bad
Old Apr 24, 2006 | 11:05 PM
DONAIMIAN's Avatar
emission fittings?
Old Apr 24, 2006 | 11:09 PM
DONAIMIAN's Avatar
dude, im still feeling the after shocks from saturday night
Old Apr 24, 2006 | 11:13 PM
408WS6's Avatar
damn I like that ws6^^^
color looks good on that car
Old Apr 24, 2006 | 11:49 PM
Moderator
Originally Posted by DONAIMIAN
emission fittings?
Duobt it, coming from the passenger side head area, the car is open header loud, to bad it just sounds like ***.
Old Apr 24, 2006 | 11:51 PM
FIREHAWK #07's Avatar
damn neil youve been having some bad luck the last couple of weeks....Think its time for some LT's on that biatch...
Old Apr 25, 2006 | 12:29 AM
SUTTERERMAN85's Avatar
it could be the air injecton check valve thing. its on both sides and they get brittle as hell. it would sound like **** also.
