01 Silverado Question
Looked for the leak when i got home and didnt find any leaks from the hoses or connectors. However i couldnt see **** cause all the intake and fan shroud in the way However i did see some fluid on the bottom of what looked like the water pump. Is there anything I should look for and where should I look. What should i remove or move out of the way so I can actually tell where the leak is coming from.
I searched and found that most of the problems stem from the water pump / gaskets in water pump.
The truck is an 01 with the 5.3L and has 80K on it. Guessing its the water pump
Posted this on the truck tech site yesterday and got nothing...couldnt hurt putting it here also. Since everyone has a truck in Texas right?
I have a 02 Silverado & my truck will give me a Low Coolant light sometimes too. I can't figure out why, I have looked for leaks & never find any. I rarely get the light. But it happens to me also. So your not alone!
If theres no leaks, With the LT1s when they did that it ended being a bad filler neck sensor.
Thanks for the help!
00NBMCamaro - Good to see you found the cause. Fixing it shouldn't be too difficult. Just be glad it's not an LT1
Tom
Why the hell wasnt there any seepage from the weephole YESTERDAY!!!!!!!!
