Battery Voltage
Old Jun 29, 2006 | 07:23 AM
Splitz's Avatar
Default Battery Voltage
Assuming that your battery is "Good", what should the voltage read @ the battery terminal with a meter?
Mines reading about 8-10v's and the car won't start, no radio, seatbelt light comes on and off, tach and speedo jump, then goes down. Fuel pump SOUNDS like it's trying to pump, but no other dashboard indications except seat belt light.
Battery dead or low v's?
Splitz
Old Jun 29, 2006 | 07:49 AM
aggiez28's Avatar
if the cars off it should be around 12. if its on it should read more than 12
Old Jun 29, 2006 | 07:59 AM
01ArcticSS's Avatar
Splitz
Should be 12V - batteries usually have six "cells" each with 2V. If you're reading 8-10 you probably have a bad cell.
Old Jun 29, 2006 | 10:56 AM
DONAIMIAN's Avatar
13.5 volts when running. Around 14.0-14.2 on a cold start.
