Idling problem...
Old Sep 9, 2006 | 12:38 PM
TX_SS's Avatar
Question Idling problem...
k here is the problem.
whenever im at the light, my car idles @ 1500 RPM and it doesnt go down to normal idling position. which is @ 900 to 1000 RPM. this doesnt occur at all times but it does do it pretty often. what could be wrong?? TB?? TUNE??
what would be the best way to find out??
Old Sep 9, 2006 | 01:21 PM
SUTTERERMAN85's Avatar
check the PCV line or the fresh air line going into the TB. on has like a 135* bend that cracks over time and will make it idle fast cause its sucking in too much air. also if you have an aftermarket TB it could be sticking.
