Need Some Help with Window Motor!!!
I did mine using that guide and didn't have a problem, aside from some itchy fingers after drilling through the fiberglass.
-Mike
yah i was able to locate the rivets, but was uncertain about getting to it...the access hole is on the opposite end of the door. I'll check out some links and see if can't make it work, thanks for everyones input.
