Headliner is falling down
Old Oct 14, 2006 | 04:33 PM
Shackleford's Avatar
Default Headliner is falling down
Anyone want to give me a quote to fix it? Thanks.
Old Oct 14, 2006 | 05:02 PM
SleeperZzZ28's Avatar
why dont you just fix it? some 3M spray adhesive should hold it up.
Old Oct 14, 2006 | 05:04 PM
ROCNDAV's Avatar
Camaros are notorious for this. My 94 is this way. On my IROCs, I pulled the headliner out and pulled off the fabric so I could get to where it was seperated. I then sprayed it with 3M Spray adhesive and put it all back together. I held until my car was stolen. I was planning on doing the same to my 94.
Old Oct 14, 2006 | 05:35 PM
Mr.Wolf's Avatar
my 87 z28's is held up with clips screws, and interior panels.
Old Oct 14, 2006 | 09:48 PM
So, would I need to take it completely off then use the 3M spray adhesive?
Old Oct 14, 2006 | 10:44 PM
BizZzatch350's Avatar
Moderator
When it happened to my TA I replaced the entire thing, ordered a complete head liner from GM, wasnt cheap. How ever, you can go to a reputable upholstry shop and a hard top should only be about 100$ to have recovered. T-tops would be a good bit cheaper, this problem has happened on every single GM car we have owned, happens on a lot of cars actually, glue wears over time, no biggy.
Old Oct 14, 2006 | 11:03 PM
Kewl_Blades's Avatar
If you are not comfortable in doing it yourself (aka search on how to do it yourself), then get it done at an upholstery shop. $100 is an average price including new fabric.
Old Oct 15, 2006 | 12:59 AM
ROCNDAV's Avatar
Yes. It is much easier that way. Just remove teh pillars, then the back panels. Pretty easy.
Old Feb 20, 2007 | 05:18 PM
Any shop hookups? I called one place in town and they said $80.
Old Feb 20, 2007 | 06:33 PM
01WS6/tamu's Avatar
80 is about in line to do that it is a fair amount of work about a couple of hours give or take.
Old Feb 20, 2007 | 07:08 PM
playtoy's Avatar
A buddy of mine has a shop in over here in Liberty he said that he gets about 125, so 80 sounds like a bargin. If you decide to do it yourself, be careful, generally it is not the glue (contact cement) that fails, it is the foam backing and if the backing is gone and you spray contact cement on the head liner it is going to bleed through and look like ****.
Old Feb 20, 2007 | 07:11 PM
I don't think I'm going to do it myself.
Old Feb 20, 2007 | 11:52 PM
2fast97Z's Avatar
yeah mine was all kind of like eaten up from water damage i guess from a previous t top leakage and then started drooping so said screw it and just pulled the thing off and i actually had to cut it in half to take it off becuase of my cage setup...if i get another one im going to have to have a custom one made
Old Feb 20, 2007 | 11:54 PM
I wish I had t-tops.
