t56 ?
Old Oct 15, 2006 | 01:25 AM
ex-SS-ve's Avatar
Default t56 ?
started my car . released the clutch pedal while in neutral position. car jumped and died. started it again put it into reverse and the car went forward. i then shifted into first gear and lost all gear engagement . car wouldnt drive in any gear position. just sat and revved like it was in neutral. any ideas?
Old Oct 15, 2006 | 11:25 AM
Inspector12's Avatar
TT-TECH Veteran
Did you go through it or someone else?
Old Oct 15, 2006 | 02:15 PM
ex-SS-ve's Avatar
it was a new t56.
Old Oct 15, 2006 | 09:09 PM
SUTTERERMAN85's Avatar
are you sure you have the shifter ball in the spot that it goes in? it is like a ball and there is a plastic bushing that it goes in. i would look there first.
Old Oct 15, 2006 | 09:22 PM
TT-TECH Veteran
Originally Posted by ex-SS-ve
it was a new t56.
This is not the one you bought from Loyd? I was told it was and that you knew it might have issues, but not really sure of what they may be. I believe one of the shafts is broken probably the imput shaft but who knows with out tearing it apart etc...
Jeff
