Need Help- Catch Can Install- $$
Old Nov 16, 2006 | 09:00 PM
1stz06's Avatar
Default Need Help- Catch Can Install- $$
I'm in the middle of installing my NLP catch can and I can't figure out how to run the hoses. The instruction suck!!!
I have a Fast 90 Intake and LS2 TB without PCV.
I will paypal you $20 if you can tell me how to run these damn hoses.
PLEASE HELP!!!
Thanks,
J.R.
Old Nov 16, 2006 | 09:03 PM
TINKRD's Avatar
this is for a AMW but should be the same!
Old Nov 16, 2006 | 09:05 PM
TINKRD's Avatar
also that is for an LS6 still PCV, if you have an LS1 style valley cover then all you would do is run the top line from the PCV hose that runs down the passenger side of the intake to the top of the catch can, then the bottom hose of the catch can would go to the intake
Old Nov 16, 2006 | 09:08 PM
TINKRD's Avatar
your specific catch can
you can see the top hose running off the PCV line coming down the intake like i described. the bottom hose runs to the intake manifold.
Old Nov 16, 2006 | 09:13 PM
Black2001z06's Avatar
My "Greddy" catch can...
TINKRD's Avatar
that enough help??
Old Nov 16, 2006 | 09:54 PM
1stz06's Avatar
Thank you guys. The winner is TINKRD!!!
PM SENT.
Old Nov 16, 2006 | 09:59 PM
1stz06's Avatar
Black2001Z06, by the way, I am going to order me one of those Greddy catch cans tomorrow. Where did you get it???
J.R.
Old Nov 16, 2006 | 10:34 PM
They are about $100 shipped.
I am pretty sure they are universal with all vehicles.
Mine came for free with the car.
I like it because you can actually see how much oil the can is catching.
Here's you a link for one on ebay.
http://cgi.ebay.com/ebaymotors/Gredd...spagenameZWDVW
They can be found all over...
Old Nov 16, 2006 | 11:19 PM
1stz06's Avatar
I guess I'll be getting rid of the one I just bought!!!
Thanks for you help sir!!!
J.R.
Old Nov 30, 2006 | 01:19 AM
Dbl G's Avatar
Old Nov 30, 2006 | 07:02 AM
fastflames's Avatar
J.R.
Stop! before you order one! I PM'ed you.
Old Nov 30, 2006 | 07:21 AM
Dbl G's Avatar
The Greddy can is terrible.
I had purchased one for my truck after it arrived I realized it was a piece of junk and spent two hours modifying it as to where it would work.
There are others on the market that work perfectly without adaptations.
The Greddy is now on my Bimmer.
Garrett Gunther
Old Nov 30, 2006 | 07:25 AM
TheBlurLS1's Avatar
That's what she said...
LS2 TB has no PCV? You need the "fresh air tube" going from the valve cover to in front of the throttle body blade.
This port is always at a higher pressure than the PCV inlet behind the blade, which causes air to circulate into the crank case. Without this fresh air tube, you might as well run a breather.
Old Nov 30, 2006 | 07:33 AM
Dbl G's Avatar
If I am not mistaken ,,,you may want to check with your tuner,,that would be a introduction of un-metered air and can effect your tune parameters.
Not too mention any Oil bound vapors would then saturate your T-Blades.
