differential?????
Old Dec 5, 2006 | 07:53 PM
lets_fly's Avatar
Default differential?????
i am going to replace my differential oil, how many quarts do i need, what weight, and do i need the posi additive? any info helps, lmk
oh yea, its on a 10 bolt-02 WS.6
Old Dec 5, 2006 | 09:22 PM
rod214's Avatar
13. What gear oil should I use?
You can find this in the owner's manual. Otherwise, 75w90 or 80w90 will work fine. It is not necessary to use synthetic oil. Also if you have an auburn carrier you will need the limited slip additive.
Fill it to the bottom of the filler plug hole.You'll have to stick your finger in there to check when you're close.The manual say's 4 ounces (118ml) of limited slip diff.lube additive (GM part # 1052358)
Old Dec 5, 2006 | 11:14 PM
lets_fly's Avatar
what is an auburn carrier, and how do i know if i have one?
Old Dec 6, 2006 | 11:12 AM
rod214's Avatar
Default auburn carrier
This should help.
http://www.xse.com/leres/ss/differential.html
