seafoam help
Old Dec 12, 2006 | 07:40 PM
osvaldo's Avatar
Default seafoam help
so im doing this right now and im not sure if im supposed to remove the valve from the booster when removing the hose. its squeeling like hell and im afraid im messing something up! m freaking out
thanks!!!!!!!
Old Dec 12, 2006 | 08:28 PM
LS1Aggie09's Avatar
hey man, don't worry about removing the valve...i didn't, just removed the hose from the booster valve and yea...it was hell but thats how i did it after about an hour of rocking that damn thing back and forth thinking i was gonna eff something up, but i did it 10 to 15k miles ago and yep...everythings working great!
Old Dec 12, 2006 | 09:17 PM
osvaldo's Avatar
i did it and now i hear other clinging ****, i hear some high pitched knocking coming from under neath the car. also i hear some buzzing coming from my exhaust when i push the gas peddle.
it didnt smoke up mutch, i revved the car up 2-2.5K and it did smoke, when i ran the car it smoked pretty bad, but not for long.
and my F'EN check engine light came on!!!!!!!!!!!!!!!!!!!!!!!! whats up with that? please some input will really help out.
and the brakes are working fine so im not worried about that.
my freaking stick feels loose now?????????? my clutch feels ok, but not as stiff as before.
DAMN SEA FOAM!!!!!!!!!!!!!!!!
Old Dec 12, 2006 | 09:59 PM
estegeme's Avatar
do you still have cats?
Old Dec 12, 2006 | 10:02 PM
osvaldo's Avatar
im pretty sure the cats are gone
how come?
Old Dec 12, 2006 | 10:14 PM
estegeme's Avatar
sounds kinda like you broke one, im by no means an expert, but i know some people have said that they have melted cats with sea foam befor, and i know that in my dakota it did the same stuff when the cats went outta it. go to auto zone and have that code ran
Old Dec 12, 2006 | 10:30 PM
SHINER's Avatar
seafoam should be 02sensor/Cat converter safe.
It aids in cleaning them out just keep driving around and the light should turn off.
I have seafoamed my car alot. No probs.....but i dont have cats
Old Dec 12, 2006 | 10:32 PM
osvaldo's Avatar
i let it idle for 20 mins, drove it hard for 20 mins, then let it idle for another 10 mins. when i turned it off the light was still on. ill be up and runnnig by 6am, should i keep running the car now or just drive it in to work tomorrow?
Old Dec 12, 2006 | 10:45 PM
SHINER's Avatar
I drive around for about an housr just cruising and get on it one or twice, then drive it to work tomm
Old Dec 12, 2006 | 10:52 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I think you will be fine. Mine sounded horrible when I was driving it and when it was idling while being poured in. It is all in your head....but the reason that is; because you are pouring foreign object liquid into your perfectly normal running engine.
Old Dec 12, 2006 | 11:00 PM
osvaldo's Avatar
update: just drove to the gf's house, the CE light turned off. the car does feel little better. maybe once i change the oil i will feel the difference.
on a side note. my car idled BAD when i took the hose off. but when i poured in the seafoam through hose, the engine would rev. that sound about right?
Old Dec 12, 2006 | 11:05 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Normal. You were creating a vac leak...that was your bad idle. Seafoam is flammable. It was getting burned with the A/F mix. There was your high revs.
Are you cammed? Heads/Cam cars are even worse.
Old Dec 12, 2006 | 11:35 PM
osvaldo's Avatar
na bone stock
hopefully i will get some headers soon though
thanks for all the help everyone!
Old Dec 13, 2006 | 03:21 AM
AGRV8D's Avatar
WTF is the seafoam used for
Old Dec 13, 2006 | 04:16 AM
SRT2LS1's Avatar
Cleaning the inside of the engine, removes built up gunk.
Old Dec 13, 2006 | 03:31 PM
playtoy's Avatar
I seafoamed mine a couple of days before I sucked a bolt down the intake, when I pulled the heads off I couldn't believe how clean the pisions looked. IMO seafoam is the ****.
Old Dec 13, 2006 | 04:02 PM
sportinss's Avatar
I read through the whole seafoam Sticky, Im going to to mine this weekend. Ill givee an update and some pics on how it went.
