Radiator Question???
Old Jan 8, 2007 | 03:26 PM
99TA04's Avatar
Default Radiator Question???
I think i have a radiator leak and i was wondering if the radiator is the same size in the trans am as the firebird let me know
Old Jan 8, 2007 | 05:10 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
If they are both LS1s then I say yes they are the same.
Old Jan 8, 2007 | 05:18 PM
CRAGER's Avatar
Administrator
If you are asking if the V6 Firebird is the same I'd say call your local dealership and ask if the parts numbers are the same.
If they do not wish to help you, look it up on GMPartsdirect.com to see if they are the same number.
Peace,
Craig.
Old Jan 8, 2007 | 05:29 PM
TexasVortexx's Avatar
Be certain to specify A4 or M6. The A4 Radiator has provisions for transmission cooler lines. If buying used you could simply block off the fittings for an A4 radiator but you couldn't use an M6 radiator on an A4 car.
Old Jan 8, 2007 | 06:14 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
The V6 and V8 radiators DO have different part numbers. Also, on the OE parts, there are different part numbers for an automatic car and a manual. Hope that helps.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jan 8, 2007 | 06:21 PM
ls1_doc's Avatar
Yeah but like vortexx said you can use the auto radiator for either car. Although the rad for the manual is probably a little cheaper.
Old Jan 8, 2007 | 06:36 PM
99TA04's Avatar
alright thanks guys
