Dyno Results: Conley Performance :{
Old Feb 14, 2007 | 01:22 PM
  #41
freni32's Avatar
I definitily need to get the wheels smaller! What is the best for 1/4 times... which is my concern..... 16's or 17's ?
I just thought something was wrong with the air/fuel ratio.... seemed very lean still.... and the numbers seemed very low.... just wasnt sure what was going on.... I wasnt looking for any gains in HP from a tune.... just that it should be at least in the 320-330 range... and my car was running lean when I brought it in there... wanted to get that taken care of.... main reason for the tune.
Does our cars come stock with 320 to the flywheel or to the rear wheel?
Old Feb 14, 2007 | 01:25 PM
  #42
1320FEVER's Avatar
16's. The more sidewall the better.
Old Feb 14, 2007 | 01:30 PM
  #43
kornfreak_401's Avatar
did you change your spark plugs before the tune? i'd go with 15's or 16's. I think factory was something like 315 to the wheel. new O2 sensors would help. did jeff delete your rear O2's?
Old Feb 14, 2007 | 01:41 PM
  #44
BLACKND's Avatar
All modern factory HP #'s are rated to the flywheel, if your car is an automatic then you have to account for drivetrain loss.
Old Feb 14, 2007 | 02:03 PM
  #45
freni32's Avatar
My car is a manual.... they just put on new spark plugs with the longtube installation.... say 1,500 miles ago...
The O2 Sensors have about 60k on them on the front.... the rear have the O2 simulators plugged in.... he deleted the rear O2's for me... can I take the O2 simulators off the rear now since they arent working because of the delete?
I am posting up the dyno results on first page now.
Old Feb 14, 2007 | 02:06 PM
  #46
freni32's Avatar
Im new to reading these dyno sheets...... looks like my top end is 141 mph? Thinking those 20"s really are killing the top end speed as well!
Anyone want to trade for some 16's? lol
Old Feb 14, 2007 | 02:18 PM
  #47
-Ross-'s Avatar
Dude...Do the math. Others have said Mustang dynos read about 10% lower than Dynojets.
320 x .10 = 32
320rwhp – 32rwhp = 288rwhp
Technically, you got what you were hoping for. With a better wheel/tire combo you could be around 330rwhp on a dynojet.
Old Feb 14, 2007 | 02:21 PM
  #48
freni32's Avatar
thats good.... I am new to dynos... didnt know mustang dynos rated lower then dynojets..
looking at the charts on the first page... I gained about 10-15 more hp to the rear with the tune?
Old Feb 14, 2007 | 02:35 PM
  #49
Nine Ball's Avatar
LS1Tech Co-Founder
That is your top speed in 4th gear. Our cars pull the actual top speed in 5th gear.
You went from 278 rwhp to 289 rwhp. + 11 rwhp from tuning. That is about normal for the limited mods you have on the car.
And: http://www.cafepress.com/ls1tech.9477547
Old Feb 14, 2007 | 02:39 PM
  #50
freni32's Avatar
Great, thank you. I will buy the shirt from the link
Old Feb 14, 2007 | 03:52 PM
  #51
So the moral of the story is?:
Know your stuff before you dyno
Smaller wheels
account for EVERYTHING
Bigger and better bolt on's before you invest on tune/dyno
Don't expect big #'s from bolt on's
RESEARCH
Most imporant, DONT badmouth anybody/place without prior knowledge
Jerry
and yes sell your O2 sims
Old Feb 14, 2007 | 03:59 PM
  #52
chupr0kabra's Avatar
Disagree. Find a shop that does either free or cheap re-tunes as your setup changes. Then it becomes VERY worthwhile.
-Mike
Old Feb 14, 2007 | 04:56 PM
  #53
exactly. but all he had was bolt on's. do a dyno tune when you have something worthwhile of a dyno tune so you can see big # increases not 10-15 or when you ar + that you are comming back with more things... but i can't agree more with you.
J.
Old Feb 14, 2007 | 05:02 PM
  #54
white man's Avatar
like i said earlier i have the same basic bolt ons and my car feels and drives much better after the tune. I see nothing wrong with that if you can afford it.
Old Feb 15, 2007 | 02:47 AM
  #55
freni32's Avatar
Smaller wheels
RESEARCH
Jerry
I wasnt bad mouth anything... just wasnt happy with the numbers... nothing about the place *** HOLE..... put your tail between your legs and walk the other way... Moral of the story... dont be an *** hole!
Old Feb 15, 2007 | 02:48 AM
  #56
freni32's Avatar
I feel a difference after the tune, it was worth it
Old Feb 15, 2007 | 11:24 AM
  #57
wooa woooaaa woooaaaa buddy, i'm not trying to be an *******! if i did you'd know Seriously, good luck with everything though...
Old Feb 15, 2007 | 11:30 AM
  #58
chadtx01's Avatar
J.
I was tuned with bolt on's and went from 311/321 to 353/362. Id say thats pretty worthwhile.
Old Feb 15, 2007 | 01:14 PM
  #59
freni32's Avatar
nice numbers! what shop did you do the tune with?
Old Feb 15, 2007 | 01:24 PM
  #60
V6 Bird's Avatar
Originally Posted by allngn_c5
Should've went to LG Motorsports for your tune.
What kind of swing set is that you have?
