I need an LT1 guru
Old Feb 16, 2007 | 06:54 PM
ckyconan2003's Avatar
Default I need an LT1 guru
Is this supposed to happen?
When it turn the key off, my fuel pressure goes from 40PSI to 0PSI.
Is that supposed to happen?
Old Feb 16, 2007 | 06:58 PM
rayosequis's Avatar
No, it should bleed down slowly. Maybe you have a bad fuel pressure regulator or check valve in the fuel pump. Does it take a while to start ?
Old Feb 16, 2007 | 11:21 PM
she starts right up, but you can tell one cylinder isnt firing at all period.
Old Feb 17, 2007 | 11:16 AM
BP's Avatar
BP
Could also be a clogged open or cracked injector. The pressure should hold for at least 10 minutes.
