Paging Dan03mach1
IM gonna bust that MACHs *** for $20 here real soon whenever you are ready.
We have 2 bets
1st bet
Motor to Motor you leave on 2nd Yellow & I leave on Green at K-Dale. I GOT THIS RACE IN THE BAG
2nd bet My Motor to your Spray (WHATEVER SHOT YOU WANT TO SPRAY) for $20 Heads up. I think the odds are in your favor on this race. But I will come correct. TRUST ME
ALSO I DOUBT YOU WILL RUN BETTER THEN A 6.80 on the spray.
You are fast with no hp because your car is LIGHT
Get some good suspension in the *** and it will fly. Dont worry about the not squatting right now. You need to worry about transfer. As Madman says, "Race cars dont squat, only girls do!"
With driver I bet it weighs 2950 or so..
I should have my ducks in a row by mid next week, I'll be getting in touch with you.
Believe it or not the Textrailia single setups are stock Luk/Valeo Pressure plates. The disk is what is somewhat special. Its out of a HD dump truck..LOL
Its also a 26 spline. I ask because a disk is a disk, Dan. The only problem with the 11" stuff is the surface area. Getting 650hp out of what you have will be like winning the lottery. Now if it was a 12" setup like the Tex stuff then you get another 1/2 or better of pressure plate material and an inch on the disc to grab the flywheel.
An 11" setup uses a 10 5/8 or so disc. 12" setup uses 11 5/8 disc. I wanted to see a stock Mach flywheel simply to see if the 12" setup will still bolt up with minimal modification like the Tex stuff does on the GM cars. Ive sourced all the parts they use and get the better stuff at a fraction of the cost. Tex clutches feel like stock...cause they are stock in the pressure plate area. Its out of a 2500 GMC truck..lol
