Snapped ANOTHER bolt....
Old Mar 12, 2007 | 06:02 PM
ckyconan2003's Avatar
Default Snapped ANOTHER bolt....
The bolt connecting the pressure plate to the flywheel.......impact gun snapped it right off...i dont own a torque wrench nor do i know the torque specs....
Anyone got one of these?
Old Mar 12, 2007 | 06:43 PM
mycamaroSS's Avatar
haha, man you best be careful when dealin wit dat stuff
Old Mar 12, 2007 | 06:48 PM
Josh McGrath's Avatar
man suck huh? I broke so many damn bolts in my TA. Hence is why the valve cover is held on by 2 bolts and RTV
Old Mar 12, 2007 | 06:54 PM
1320FEVER's Avatar
I hope your not using that impact gun to put the bolt on are you? If you are then you will continue to snap bolts. You should get a torque wrench, period.
Old Mar 12, 2007 | 08:33 PM
i start eh screws, it just kept spinning. I got the torque wrench. But i still dotn know what the specs are...
Old Mar 12, 2007 | 10:01 PM
V6 Bird's Avatar
Making rookie mistakes here. First one huh?
Old Mar 12, 2007 | 10:41 PM
chupr0kabra's Avatar
Found this in the Gears and Axles forum:
http://fbodyknowledge.org/media/fbodytorque.pdf
Print it out, laminate it, and staple it to your garage wall.
-Mike
Old Mar 12, 2007 | 11:12 PM
BBADWS6's Avatar
Do not use an impact gun on that stuff. You will continue to cause yourself pain and suffering! I think there is a read at install university, or ls1howto
Old Mar 12, 2007 | 11:49 PM
5w20's Avatar
i impact everything on, just gotta now what setting to use and when to stop. Only things i torque down on vehicles are cam caps on OHC cars and heads on both types of engines.
Air tools = your friend that makes work easier and faster
Old Mar 13, 2007 | 05:34 PM
WOOT FOR TORQUE SPECS!!!
Ima steal my friends torque wrench tonight and get crackin'
Old Mar 13, 2007 | 06:29 PM
ZONES89RS's Avatar
In-Zane Moderator
That sukks bad, i allways impact on my flywheel, never happened to me yet.
