low coolant light
i already checked (visually) waterpump/radiator but there is nothing wrong with it. car is NOT over heating. i check the coolant level and it was full. although i did add some distilled water/coolant in it. maybe half a quart.
what else is there i should check for? any advice?
the car is 99 and has 92xxx miles on it. i did coolant flush last year with valvoline.
any advice will be great. thanx
he said it works on a float switch and it can get stuck from time to time. so
aslong as you are full on coolant and not over heating it is probably the same thing
