tie rods?
Old Aug 13, 2007 | 09:46 AM
2KnbmTA's Avatar
Default tie rods?
im replacing my inner and outer tie rods, and was wondering if there was a particular brand i should go with, or would the ones from o'reilly's be ok? also, i have a power steering leak out of the drivers side dust boot, what parts are in there that i can replace?
Old Aug 13, 2007 | 02:17 PM
SS SLP2's Avatar
"Moog" from orilleys are the better grade, will be fine , as to the leak not much you can do about it, I am pretty sure you can do no good replacing seals, if it gets bad I think you must replace rack,I would not worry untill it gets bad , I see many that leak ( seep) a little
Old Aug 13, 2007 | 02:27 PM
bmxer8699's Avatar
with the tie rods, i just replaced mine. i just bought what oreily had. they work fine
