Mototron 60lb Injectors
$310.00 LOCAL
$315.00 SHIPPED
Compare at $499.00 http://www.not-a-sponsor.com.org.gov.net
Specs.
60 Lb High Impedance Injectors (Set of 8)
These are High Impedance/Resistance (~12/16 OHMs) for use with the stock EEC computer (will work with aftermarket systems as well). High impedance injectors can be used in conjunction with the stock EEC to help vehicles pass emmisions, especially with today's 1996-present OBD-II computers and emmision testers.
Using high impedance injectors also helps cut down the cost of upgrading your fuel system by allowing you to use your stock EEC computer and harness (chip/tuning required). No expensive aftermarket computer system required.
I will have up Pics tonight!!!!
Please do not post any non-sponsor contact info.
Thanks,
Craig.
LS1TECH.com Staff
