Driving in this Rain!
Old Aug 16, 2007 | 08:08 AM
camracingah's Avatar
Default Driving in this Rain!
Do people who have true duals and lowered F-Bodies have problems when crossing through large areas of water? It seems when I have no choice and go through the water the check engine light comes on the Z will want to shut down and he then has to be parked. Just want to know if others experience this?
Old Aug 16, 2007 | 08:14 AM
Morbid's Avatar
Never had that problem, but I usually avoid driving into big puddles.
Old Aug 16, 2007 | 10:04 AM
lt197formula's Avatar
Never had that problem when the Formula was still the daily...maybe a loose or bad o2 wire?
Old Aug 16, 2007 | 10:09 AM
I never thought of that. Maybe? I usually have to park him and let him "dry-out".
Old Aug 16, 2007 | 12:24 PM
LS1powerhouse02's Avatar
do you have o2 extensions? When i had the extensions that came with the pacesetters they would get wet when i drove in the rain and i would have to let it sit for atleast a day before i could drive again. That might be your problem.
Brent
Old Aug 16, 2007 | 12:28 PM
ZONES89RS's Avatar
In-Zane Moderator
Let me not speek of the OPTISPARK
anLS1x2's Avatar
It's happened to me twice. No true duals. Both times it was the passenger side O2. Probably has something to do with extreme hot meets very cold.
Old Aug 16, 2007 | 12:44 PM
Mike96z's Avatar
i got an LT1 with LT's and Xpipe, very low to the ground, probably 3" at most from the ground, and yes I had to sit at a light in a puddle of water and going threw them, would make the car run like ****, and it wasnt the opti, not sure if the exhaust was suckin water or the o2's were soaked, or hot meets cold. After that, car ran like it had water in the cylinders, would misfire and ****. Parked it and let it dry, ran fine afterwards and i did get the light and it wanted to die.
Old Aug 16, 2007 | 12:49 PM
Morbid's Avatar
Old Aug 16, 2007 | 12:55 PM
I think that's exactly what is happening. If I have to go through lots of water it misfires and turns sour *** ****. He has to be parked and dry out. Today with the weather I think I will leave him in my parking spot at the garage at work and just tell the security to check on him at night. I will give them the okay to fire at will if he moves and I'm not behind the wheel.
Old Aug 16, 2007 | 01:22 PM
TXZ0603's Avatar
Hmmmm water........
Uhh I try not to , but that dosnt help your thread on F-bodies
Old Aug 16, 2007 | 03:03 PM
txh0tb0i972's Avatar
yes!!! when i first got my car i had to go throw a puddle of water and i had to buy a new o2 and it was the pass. side
Old Aug 16, 2007 | 03:50 PM
cptncdy's Avatar
my car starts acting crazy if i drive through a puddle also. i didnt even try driving my car home today, i left it in our warehouse at work and drove the shitty work truck home.
Old Aug 16, 2007 | 04:00 PM
INVISIBLEZ's Avatar
I won't even drive my car in weather like this. You're asking for trouble.
Old Aug 16, 2007 | 04:11 PM
GTBill's Avatar
obviously dont go through water if you dont have to,but if you have to don't let off the gas when you're in the puddle...if you're lowered and have TDs then you can suck water back up into your engine through the exhaust...im sure you already knew that but just makin sure
a couple of weeks ago a sucked a bunch of water into my air filter (k&n) and when i checked it later that day, i dumped water out of the filter lol
anyhow my CEL light never came on and the car still ran fine through the water and after (till i got home, never started it again until after i cleaned and reoiled the filter) and my exhaust hangs lowwwwww...and my o2s are way down there too, im sure the mid pipe was dragging through the water...but no CEL so for mustangs i guess if the o2s get wet the light doesn't come on but i dont know if its the same for f-bodies...it probably isnt...im stil convinced yall's engines run on which craft
ino's Avatar
ino
My SS does not see rain. Hell I have a hard time in the 3rd gen let alone tring to drive the 4th with more power. Thats a no no.
Old Aug 16, 2007 | 10:10 PM
Reject's Avatar
hmm interesting, going to check my a TA for the same symptons
Old Aug 16, 2007 | 10:21 PM
98mysticZ's Avatar
yea mine does it only thing i can think of is water getting into the pass side connector and clogging up the "refrence" tube in one if the wire... not allowing it to get the right reading.... that sound good? lol dont know why it does it but is always the pass side o2
Old Aug 16, 2007 | 11:51 PM
INVISIBLEZ's Avatar
There were two young guys pushing a red LS1 T/A on San Augustine here in Deer Park today. I've seen the car @ a house on S.A. I drove to the car wash earlier and it was in the driveway. Lucky for him it took a **** a couple of blocks from his house. I would have stopped and helped them but one of them looked @ me funny because I was driving the Malibu. Oh well, atleast I was driving and not pushing, lol.... My Z was parked, and out of the weather.
Old Aug 17, 2007 | 12:20 AM
ZONES89RS's Avatar
In-Zane Moderator
Well, how do people come off saying that water can enter your exhaust when you let off? Even if it did go in a bit threw the tip it would never make it up the headers/manifilds, worst case even if it did happen would get the O2s....i dont see it happening.
