F/S Harland Sharp 1.7 non adj
when i was looking for rockers for my heads i read threads where a guy had used stock rockers on his tea/tfs heads and they ruined his valves. i sure hope rpm pays for your head work to be redone and valves to be replaced if you have any problems.
If he's got any other kind of 5.3 or LS6 heads, then he's ok.
good question arises: how many CFM does a maf allow you to flow. IMO at 85mm that is just the diameter... so indeed if you have a 90/90 setup the 85 will still be a restriction. I would go SD if you are wanting max effect. 85mm diameter does not mean it is truely 85... it still have the foil thingy in the middle.
Just like putting injectors in and not having them properly scaled.
Good luck bro.
