O2s SLOW TO RESPOND
Old Oct 20, 2007 | 02:14 PM
my number 1 hater's Avatar
Default O2s SLOW TO RESPOND
MY 98 Z28 keeps throwing the code O2s slow to respond......what is the dang deal, i have changed them 2 times .... long tubes no cats the rear O2s have sims....But the front 2 (these are the ones throwing the code) are the longer wired vett type.....bosh pn 13111....
HAS anyone had this problem????
Old Oct 20, 2007 | 07:49 PM
txh0tb0i972's Avatar
is it just throwing the code or does it stutter? I had a stuttering problem like it wouldnt want to accel. but then i unpluged my o2 then it work so i knew which one to replace.... we are also having the same problem with a friends car so if you find out let me know plz... thx.... i know its not much but just trying to share some info with some o2 problems i had maybe you can relate 2
Old Oct 20, 2007 | 08:22 PM
im working on it bro....... i have posted this on several forums still no response.....You would think this might be a common problem with long tubes... Hope its not just a problem with 98s
Old Oct 21, 2007 | 12:26 AM
ULTX's Avatar
I had the same exact problem about a week ago. Mine kept throwing some bank1 sensor 1 not being active/ slow response codes. Just go to NAPA and buy their oem(BOSCH) sensors and extend them youself that solved my problem
Old Oct 21, 2007 | 12:34 AM
FIREHAWK #07's Avatar
so how did you extend them yourself??? You cut into a brand new sensor...
i would hate to buy a new sensor and then have to cut it....
Old Oct 21, 2007 | 01:38 AM
DFWGrant's Avatar
Does the SES light actually come on?
Hotboi - when you say stuttering, for instance if you're driving @ 60-65mph and you floor it and the RPM's shoot up, but it takes a few seconds for it to start moving like it should?
Old Oct 21, 2007 | 08:02 AM
ULTX's Avatar
The people at napa advise you to cut BEFORE the 02 sensors but its alot easier to cut and extend the sensor, i know i felt kinda bad to cut open that brand new sensor but it all went away after everything worked
Old Oct 21, 2007 | 08:27 AM
thanks bro..... any chance your know what gauge the
O2 wires ARE...
Old Oct 21, 2007 | 08:34 AM
A-Dub's Avatar
The particular sensors you bought aren't necessarily the solution. New sensor may cover up the problem for a while but it will probably come back. The code is getting thrown because you have longtubes and the O2s are responding slowly when the computer goes into closed loop. Its a common problem with 02s and longtubes since the sensor is moved away from its stock location and placed much further downstream. For some reason, the 98s seem to be more picky. You may also have an exhaust leak that is adding to the problem.
Old Oct 21, 2007 | 03:42 PM
SSkillz's Avatar
Yeah my went out and put a new one in and it still doesnt work!!!
Old Oct 21, 2007 | 07:36 PM
ULTX's Avatar
check for exhaust leaks, i know i found a small leak on mine too
Old Oct 21, 2007 | 08:36 PM
no when your just driving it just starts to hesitate...like sputtering...but when you floor it .... it goes away
Old Oct 21, 2007 | 10:14 PM
joshtownsend's Avatar
The thickness does not matter but i will do it for you if you want me to.. I used 18/4 on mine and i have plenty left.. just bring them by and I'll hook you up!!!
Old Oct 22, 2007 | 09:45 AM
score one for the home team!!!!
Old Oct 22, 2007 | 09:48 AM
I got under the car on sunday and found 2 exhaust leaks!!!!!!!!!!!! Working on fixing them today....
Old Oct 22, 2007 | 10:18 AM
A-Dub's Avatar
Good, hopefully new sensors and no leaks will have the car running good.
Old Oct 22, 2007 | 12:04 PM
Exhaust leaks or cutouts???? I think cut outs are suppose to be there!!!!!
Old Oct 22, 2007 | 10:20 PM
HAHAHAHAHAH!!!!!! Dude did u eat paint chips as a KID?????
Old Oct 22, 2007 | 11:23 PM
Mikey-Z-28's Avatar
If your car has been running rich the CO will cover the sensor and give it a slow switching syndrom. If you had someone with a scanner look at your Fuel Trim then it would be a lot easier to narrow down.
Old Oct 30, 2007 | 08:46 AM
Problem fixed..... New stock O2s custom extended by Josh ( thanks Bro ) EXHAUST leaks also fixed.... No more problems......... SWEEEEEEEEEEET
