Where can I buy this?
Old Nov 12, 2007 | 03:15 PM
Mike96z's Avatar
Default Where can I buy this?
Im needing to buy a longer push rod for the slave cylinder on a 92 Camaro with the 305. The problem is the clutch that I got, wont disengage all the way so a longer rod seems to be the answer, all installed correct, new clutch fork and all. Thanks
Old Nov 12, 2007 | 04:22 PM
Mike96z's Avatar
anyone?
Old Nov 12, 2007 | 05:21 PM
WOTFMAN's Avatar
You dont buy longer rods...You make it longer buy cutting it and threading it so it will accept a long extension nut. Then its called adjustable
Old Nov 12, 2007 | 06:45 PM
Mike96z's Avatar
pics of this process?
Old Nov 12, 2007 | 08:29 PM
BuckaroooZ28's Avatar
its a sticky in the trans section i think
Old Nov 12, 2007 | 09:29 PM
Mike96z's Avatar
thanks ill go check
