more bad luck.
Old Nov 29, 2007 | 04:55 PM
slohemi's Avatar
Default more bad luck.
In addition to my truck not starting the trans am started ticking today. Sounded like a lifter so i took it by the Auto Shop. The owner Chad is a pretty cool guy told me it could be a bent pushrod or a broken valve spring. Anyways he told me to pop the valve cover off and check it out. Looks like i get to spend all weekend working on cars lol. If anyone has pushrods,valvesprings, or lifters laying around let me know..i may be in the market.
Old Nov 29, 2007 | 05:26 PM
slohemi's Avatar
Also if the valve springs and pushrods check out what do i look for as far as the lifters are concerned to tell if its bad? Any tips would be appreciated.
Old Nov 29, 2007 | 05:43 PM
I8ASaleen's Avatar
any scoring, or irregularity on the lifter is pretty much not good.
Old Nov 29, 2007 | 07:23 PM
slohemi's Avatar
how hard is it to get to the lifters?
Old Nov 29, 2007 | 09:09 PM
khaos288's Avatar
you have to take the heads off, i have some stockers if you want em but i wont be back at my garage till the 15th
Old Nov 29, 2007 | 09:34 PM
slohemi's Avatar
i dont want to take a head off. Is there a write up somewhere that gives info on how to do it and what specs to torque everythign down to?
Old Nov 29, 2007 | 10:32 PM
khaos288's Avatar
ls1howto.com and do fbod head swap, and thats the only way to get the lifters out, sorry man
Old Nov 30, 2007 | 11:09 AM
chrysler kid's Avatar
i had a valve spring go out on my ss, it made the car run like crap and made a ticking noise. look for a cracked spring, your gonna need a flash light, even after he told me it was a busted spring and i looked under the hood i didnt notice until the tech pointed it out. to swap a spring i dont think you need to take off the head, but there is a chance you bent a valve and did some damage to the piston (although you would notice your car would basically be running on 7 cylinders even after you replaced the spring)
keith craft in plano charged me $800 for install and comp springs, so expect like $200 less from just a regular shop
Old Nov 30, 2007 | 03:18 PM
slohemi's Avatar
Well i got my truck running today so thats good. Im gunna tear into the trans am tomorrow morning probably. Hopefully its somthing simple but with my luck it wont be lol. I guess if it gets bad it will give me an excuse to toss a bigger cam in there.
