What tips should i get?
Old Feb 16, 2008 | 05:08 PM
dshag's Avatar
Default What tips should i get?
I have the stock square one and i like the 3in to 3 1/2 in slach tips the only thing is i have the body kit so im worried about clearance and scraping/knocking them off
Old Feb 16, 2008 | 05:22 PM
6THZ28's Avatar
so you have stock exhaust? i'd say get some headers and y, and choose whatever cat back you want.. body kit doesnt matter in this case unless you have your car lowered, any tips will be ok
Old Feb 16, 2008 | 05:30 PM
ex-SS-ve's Avatar
i would just get a set of slp dual dual tips. i think you would be happy with those. howevre the square one you have now are stock z28 tips?
Old Feb 16, 2008 | 05:40 PM
Blue's_Z28's Avatar
I have the GFX kit as well with a magnaflow catback. Clearance on the rear kit piece isn't an issue but then again I cut 3.5" off of the tailpipes so it wouldn't look like a truck exhaust.
Old Feb 16, 2008 | 05:50 PM
dshag's Avatar
I guess ill just have to see how it works out, i bought it 2 weeks ago and the only mod i know it has for sure is a lid, it seems like it sits pretty low but im not sure, i also believe it has a cat back on it, One of my dads buddies was checking it out and said that the cat back was shortened and it appeared to be good quality work. Im kinda new to some of this so sorry if i dont give good descriptions. And yes it has black square tips that are probably 1 or 2 inches short of the outside edge of the bumper
Old Feb 16, 2008 | 06:33 PM
dshag's Avatar
Well i decided to slide under the car and check in the garage. It already has a catback sys, i didnt see/read and brands on it but it sounds really healthy and is quiet so im guessing the LMII but i could be wrong. I really need to get LT's and a Y pipe the pipe run is oval shape and small, must kill the flow
Old Feb 16, 2008 | 08:53 PM
TXZ28LS1's Avatar
i would do some corsa tips!!
