lost keys
Old Mar 10, 2008 | 11:08 PM
FIREHAWK #07's Avatar
Default lost keys
if someone lost both sets of keys to a vehicle.... can you just go upto the dealer and get another set done/ordered need key fob too???
ITs a dodge truck.... $$??
Old Mar 10, 2008 | 11:13 PM
TXB4Z's Avatar
They should be able to cut you a key off of the vin but most dealers will require you to bring the title of the vehicle in with a matching photo ID.
Old Mar 10, 2008 | 11:21 PM
Morpheus's Avatar
Also, if it's a newer one with the electronic key, the truck will have to be towed to the dodge dealer so that they can program the key. It's not cheap. Get ready to pay close to $200 for the key/remote and probably another $100 for programming.
Old Mar 10, 2008 | 11:24 PM
TXB4Z's Avatar
I didn't even think about that being a Dodge. I work at an Acura dealer and our cars are the same way. **** adds up quick!
Old Mar 10, 2008 | 11:30 PM
well... the key doesnt have the "chip" visible like the LSX have etc.... anyone know for sure if it needs to be towed upto the dealer ship
Old Mar 10, 2008 | 11:35 PM
Morpheus's Avatar
What year model? None of the cars have a visible chip anymore.
Old Mar 10, 2008 | 11:37 PM
the truck is a 2003;
I assumed that the ls1's had a visible chip like my lt1..
Old Mar 10, 2008 | 11:41 PM
Morpheus's Avatar
Well yes, those cars do but they used the old style 2 key system. I'm talking about 2003-later cars. Some don't have chips at all but almost every new car now has one embedded in the key where you can't see it.
I'm not positive but I don't think your truck has the chip in the key. I could be wrong. You'll need to call the dealer to make sure.
JScamaro's Avatar
You are correct. My 2002 model has a chip in the key.
Old Mar 11, 2008 | 10:06 AM
5w20's Avatar
this guys right...im pretty sure since its a newer truck it has to be programmed
buy expensive key
get key programmed (which means vehicle needs to be there to get programmed)
key, tow, programming key is atleast $200 berto...
talk to cabesas maybe he can get you hooked up at the dodge dealer...
Old Mar 11, 2008 | 10:12 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
If the head of your old key was black it didn't have a transponder, and if it was gray it did. So, if it was black you can just get them to cut you one, if not you will need to call a locksmith to program you one (cheaper than towing). I made and programmed those keys for $125 but most places in decent sized cities charge $200 for your key. Get two keys at once, it's generally only $15-$10 for the 2nd one at the same time. Where are you located in Texas?
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Mar 11, 2008 | 10:07 PM
im near Houston...
And you sir were correct. Its a black key and.... it cost $10/key; and $35 for the key fob.
thanks for the info.
Old Mar 11, 2008 | 10:08 PM
buy expensive key
FAIL ABIEL.
what happened to head; he doesnt work at H nomorzzzz
