quick question
Old Mar 17, 2008 | 09:45 PM
slohemi's Avatar
Default quick question
Figured i could get a quick response in here. My clutch pedal likes to stick to the floor board after hard shifts and sometimes when i get on it and push the clutch in it stays in gear for a few seconds. Also its hard to get in gear sometimes...i have to pump the clutch a few times. My question is does this sound ike a hydraulic issue i.e slave or do i need a new clutch as well?
Old Mar 17, 2008 | 09:54 PM
Mike96z's Avatar
yes..
Old Mar 17, 2008 | 09:57 PM
slohemi's Avatar
yes to which part..slave or both?
Old Mar 17, 2008 | 09:59 PM
GunshotZ28's Avatar
I had the exact same problem. What I did was get an LS7 clutch kit from SDPC along with a slave cylinder and slave shim from Seed Inc. It solved all my problems. It wasn't expensive at all.. Don't even bother fixing one little thing at a time. Get an LS7 clutch kit and a new slave cylinder. It's better to replace both while the transmissions out anyways.
Old Mar 17, 2008 | 10:00 PM
slohemi's Avatar
If i can get away with a slave thats all ill do for now. I just need the car fixed so i can pull the motor out of my truck.
Old Mar 17, 2008 | 10:03 PM
Mike96z's Avatar
could be either, not sure. id take the master off since its the easiest and bench bleed it and reinstall, if it still does it, or you find a problem while bleeding then replace it. most likely if its the master and you try to bench bleed it and it gets stuck then thats your problem.
