change front shocks
-Mike
If that's the case, it's a whole lot easier. Read through the link I posted earlier in this thread, but skip the whole part about compressing the spring and removing the top nut. Just remove the whole spring/shock as an assembly and install the new one.
That said, are you sure it's a stock spring (or one whose ride height and spring rates you want)? If it's a lowered spring, you should get an alignment afterward, to correct the camber.
-Mike
-Mike
thank for the advise. I'M DONE... yea im getting new tires and going ahead with the alignment
