COMP Cam
Old Mar 27, 2008 | 05:54 PM
CruzinCobalt's Avatar
Default COMP Cam
up for sale LS1/LS6 cam
specs:
Intake Duration at 050 inch Lift: 232
Exhaust Duration at 050 inch Lift: 234
Duration at 050 inch Lift: 232 int./234 exh.
Advertised Intake Duration: 281
Advertised Exhaust Duration: 283
Advertised Duration: 281 int./283 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.595 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.598 in.
Valve Lift with Factory Rocker Arm Ratio: 0.595 int./0.598 exh. lift
Lobe Separation (degrees): 112
its new
$320
Old Mar 28, 2008 | 07:48 AM
up up up
Old Mar 28, 2008 | 09:49 AM
bigfatls6's Avatar
whats the part # on the cam?
