LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Texas Members (https://ls1tech.com/forums/texas-members-54/)
-   -   What do ya'll think so far?? (https://ls1tech.com/forums/texas-members/899210-what-do-yall-think-so-far.html)
WstTexas Apr 9, 2008 05:31 PM
Well I picked up my completely stock 99 Pewter WS6 on March 13 and had about $2K left over to do some mods. This just goes to show that you don't need alot of money to do some things. Here is a quick list of mods I have purchased so far:
Windows tinted
Eibach Prokit
Front Struts Replaced and alignment done
LS6 Intake
Pacesetter LT's (ceramic coated)
Mufflex Y Pipe
Redesigned Comp 918 Valve Springs
Melling High Performance Oil Pump
Comp Cams Chrome-Moly Pushrods
WS6 Short Stick
SLP Lid W/K&N
Skip Shift Eliminator
Auto Meter Shift Light w/ 6000 pill kit
and I still have a little money left over. As you can tell I am trying to set-up for a cam install. I am also planning on purchasing a Timing Chain set and Catback system (a little later). And definitely a Tune. Most of the stuff I have gotten but it is still sitting in the garage, waiting for me to put it on.
I am trying to decide on a cam and need your input:
TR 224
TSP 224R or TSP 228R
Patriot 226
I am leaning a little towards the Patriot 226 just to see what it might do. I know alot of others are big fans of the other two cams, but I want to be a little different.
Here is a pic after the Eibach Prokit:
http://i192.photobucket.com/albums/z...s%20Am/001.jpg
RickyMartinZ28 Apr 9, 2008 05:44 PM
Good looking car.
-Rick
deadlyz28 Apr 9, 2008 05:45 PM
youll regret getting such a small cam
WstTexas Apr 9, 2008 05:56 PM
Suggestion? I don't want a cam that annoys me while I drive around town.
deadlyz28 Apr 9, 2008 05:57 PM
youll want something lopey, do some research, i had the tr 224 and it made decent power with heads.
NHRAMAN Apr 9, 2008 05:57 PM
Very Nice....You are gonna love it.......:D
99problemz Apr 9, 2008 06:00 PM
my suggestion would be the tr224
WstTexas Apr 9, 2008 06:50 PM
Whatever cam I get I definitely want the 112LSA.
TexasVortexx Apr 9, 2008 08:30 PM
I dont think so, my black car with a 224 and a Yanks PT4000 with stock manifolds ran 11.92. They make good mid-range power too.
jsteele90 Apr 9, 2008 09:50 PM
dont need a big cam to go faast
Jaime SS Apr 9, 2008 10:03 PM
how much did you pay to replace your front struts?
WstTexas Apr 10, 2008 07:31 AM
When I did the Eibach Swap, I took the stock front struts to a local shop to get the springs off. They put my Eibach's on new struts and pulled my old stock springs off the stock struts. Was going to have them put the Eibach's on the old struts, but the passenger side had collected water and the nut had rust/sealed itself to the strut. They had to cut the bolt and rod to get the spring off.
Struts - $85 each = $170
Spring pull and mount - $15 per side = $30
PLus tax
Total was right around $220.
I thought that was a pretty good deal.
Nine Ball Apr 10, 2008 07:45 AM
because everyone should buy a cam based on how it sounds. :eyes:
You can make a stock cam "lope" if you set the idle rpm low enough. I never recommend cams with more than 230 intake or exhaust durations on stock cube LS1 engines with GM casting heads, for a daily driver.
PowerShift408 Apr 11, 2008 01:15 AM
Car looks great man! You'll be happy with any of those cams as well. Put some ported 5.3s with it and you'll be good to go.
WstTexas Apr 11, 2008 11:54 AM
Thanks Man!! I thought one of those 3 cams would be good enough for what I am trying to build, a 400RWHP daily driver that is reliable and still gets decent gas mileage. I have done a lot of thread searches on this site to narrow it down. It looks between these 3 it is just a personal preference. Still leaning towards Patriot 226, just to be different.
PowerShift408 Apr 11, 2008 01:08 PM
Are you trying to pass emissions with this car or is that a non-factor down there in TX?
WstTexas Apr 11, 2008 02:06 PM
Depends on the county you live in, in Texas. My county they can't do sniffer tests due to too much gas in the atmosphere (lots of oil and gas drilling) so they look up at your exhaust and make sure you have 2 Cats and that is about it.
kevin's_00ss Apr 11, 2008 02:27 PM
Takes his advise.. I went from a 236/242 to a 228/232 and gained 25whp/24wtq:judge:
2 SLOW Apr 11, 2008 02:41 PM
F13 or F14
jmdale1984 Apr 11, 2008 02:44 PM
Want to be different? Check out a Lingenfelter GT1-1 cam. My vote goes for the TSP228R though.
© 2026 MH Sub I, LLC dba Internet Brands
