FS:CFN N20 kit
1 x 10lb Nitrous Oxide Bottle In blue(anodized)
1 x Pair of steel powder coated Bottle brackets
1 x Nitrous Oxide Solenoid capable of 200hp gains
1 x Fuel Solenoid capable of 200hp gains
8 x jets for a wide range of HP settings
1 x 12 inch Blue stainless steel braided hose
1 x 12inch Red stainless steel braided hose 1 x 15 foot stainless steel braided hose (for bottle to solenoid)
1 x Pro Fogger Nozzle
1 x nozzle hold fitting
1 x 4an Bottle Nut
1 x wide open throttle switch (used to activate the system when at full acceleration)
1 x 20 inch stainless steel braided hose (from Schrader valve to fuel solenoid)
1 x fuel line adapter fitting
1 x nitrous oxide pressure gauge to go on your bottle 1 x dual solenoid mounting bracket
1 x pack of screws for mounting
1 x solenoid fitting to attach your fogger
2 x blue solenoid fittings to attach your bottle to solenoid and your solenoid to fogger
1 x 12 volt 40 amp relay with plug in harness
1 x arming switch
1 x purge kit
Kit cost 470.00 new and the purge is 90.00
only 2 bottles through it 350.00 pref. local pick up can ship if have to.
